Ecklers mi ha segnalato questo nuovo pacchetto performance per le C5!
Eckler's Corvette Performance Parts
New Product Information
C5/Z06 Red Devil Titanium/Ceramic Brake Rotors and Pad Kit
1997-04 Red Devil Titanium/Ceramic Brake Rotor & Pad Kit
Best Stopping Rotors Available Anywhere
Ultra Light Weight Improves Acceleration
Patented Ceramic Coating Last 20 Times That Of Steel
Unprecedented 1 Year Warranty Against Wear Out
Red Devil Brakes patented Titanium/Ceramic Rotors are the most revolutionary brake component in this decade. These rotors reduce reciprocating weight by 32.4 pounds over factory rotors. This reduction in rotating mass decreases stopping distances from 60 MPH by 25%. They also improve acceleration, when we tested these rotors on a chassis dyno we reduced the standard "pull time" on our test Z06 with steel rotors by .35 seconds in a normal 4th gear pull. Red Devil track testing has proven the patented coating will last 20 times longer that of a steel rotor. And that is why they have an unprecedented 1 year warranty against wear out when purchased through Eckler's. Included in this kit are specially formulated brake pads to match perfectly to the ceramic coatings. These rotors are an exact replacement of factory rotors eliminating the need to upsize to 18" front wheels like most "Big Brake" kits require.
If you are the ultra performance Corvette driver and want the BEST BRAKING, the BEST ROTOR LIFE and a BONUS with IMPROVED ACCELERATION the choice is clear, Red Devil Titanium/ Ceramic Rotor and Pads from Eckler's Corvette Performance Parts.
