Junior Member
Pogrammazione nuovo telecomando
ciao ragazzi visto che ho un solo telecomando per la macchina volevo comprarne un'altro. la mia è una corvette z05 del 2007, ho visto su internet una procedura dove bisognerebbe aprire il portellone 5 volte con la chiave ecc. qualcuno me la può spiegare punto per punto? grazie.
Immagino tu abbia una Z06
Il manuale del 2007, che dovresti avere anche tu... dice questo:
Matching Transmitter(s) to Your Vehicle
Each keyless access transmitter is coded to allow only transmitters programmed to your vehicle,
to work. If a transmitter is lost or stolen, a replacement can be purchased and programmed through your dealer. Your dealer can reprogram your vehicle so lost or stolen transmitters no longer work with your vehicle. Each vehicle can have a maximum of four transmitters matched to it.
To match a new transmitter to your vehicle when you have a recognized transmitter (two recognized transmitters are required for Canadian owners), do the following:
1. The vehicle must be off.
2. Have the recognized and new, unrecognized transmitters on your person.
3. Go to the rear of the vehicle and insert the vehicle key into the key cylinder located above the license plate. See Hatch/Trunk on page 83 for more information on the key cylinder.
4. Open the trunk.
5. Turn the key five times within five seconds.
6. The DIC will display READY FOR FOB #X, where X can be 2, 3 or 4.
7. Place the new, unrecognized transmitter in the glove box transmitter pocket with the buttons facing towards the passenger’s side.
8. Once the transmitter is programmed, a beep will sound. The DIC will display READY FOR #X, where X can be 3 or 4, or MAX # FOBS LEARNED.
9. Press the Acc button (ignition switch).
The Canadian immobilizer standard requires Canadian owners to see their dealer for matching new transmitters when a recognized transmitter
is not available. United States owners are permitted to match a new transmitter to their vehicle when a recognized transmitter is
not available. The procedure will require
three ten minutes cycles to complete the matching process. Do the following:
2. Place the new, unrecognized transmitter in the glove box transmitter pocket with the buttons facing towards the passenger side.
4. Open the trunk.
6. The DIC message will display OFF-ACCESSORY TO LEARN.
7. Press the Acc. button (ignition switch).
8. The DIC will read WAIT 10 MINUTES and will count down to zero, one minute at a time.
9. The DIC will display OFF-ACCESSORY TO LEARN again.
10. Press the Acc. button (ignition switch).
11. The DIC will read WAIT 10 MINUTES and will count down to zero, one minute at a time.
12. The DIC will display OFF-ACCESSORY TO LEARN again.
13. Press the Acc. button (ignition switch).
14. The DIC will read WAIT 10 MINUTES and will count down to zero, one minute at a time.
15. A beep will sound and the DIC will read READY FOR FOB #1. At this time, all previously known transmitters have been erased.
16. Once the transmitter is recognized and programmed, a beep will sound and the DIC will display READY FOR FOB #2.
If you have additional transmitters to program, take transmitter 1 out of the transmitter pocket and place transmitter 2 in the pocket. This can be done repeatedly until up to four transmitters have be programmed. The DIC will then display MAX # FOBS LEARNED and will exit the programming mode.
When you are done programming transmitters, press the Acc. button (ignition switch).
Detto questo, non ricordo se la procedura da seguire sia la medesima anche per le europee. Se non funziona, dovrai recarti presso un centro di assistenza.
