Pagina 1 di 2 12 UltimaUltima
Risultati da 1 a 10 di 11
Discussione: VENDO PISTONI SPEED-PRO HYPEREUTETICS +0.060"
    Marconi
    VENDO
    per cambio di progetto
    8 pistoni Speed-Pro Hypereutetic + kit fascie elastiche
    ancora imballati nelle loro confezioni originali
    SPEDIZIONI INCLUSE IN TUTTA ITALIA ISOLE ESCLUSE
    8 pistoni Speed-Pro Hypereutetic +0.060" ZH345NP60 120€
    Bore (in) 4.060 in. (103.124mm)
    Piston Style Flat top, with four valve reliefs
    Compression Distance (in) 1.560 in.
    Piston Head Volume (cc) +5.00cc
    Wrist Pin Style Press-fit
    Pin Diameter (in) 0.928 in.
    Piston Ring Thickness 5/64 in. x 5/64 in. x 3/16 in.
    Sealed Power Performance Piston Ring Sets 251K060 40€
    Top Ring Thickness 5/64 in.
    Second Ring Thickness 5/64 in.
    Oil Ring Thickness 3/16 in.
    Oil Ring Tension Standard
    File Fit No
    Gapless No
    Top Ring Material Iron
    Top Ring Facing Material Moly
    Second Ring Material Iron
    Second Ring Facing Material Cast iron
    Oil Ring Material Stainless steel
