Pagina 1 di 17 12311 ... UltimaUltima
Risultati da 1 a 10 di 165
Discussione: BIG-BRAKE UPGRADE: C6 Z06 per tutte le C5 & C6!!!
    Christian GM
    27,59KB
    The C6 Z06 Front Big-Brake Upgrade Kit includes front and rear calipers, brake pads, and rotors, everything you need to upgrade your Ø325mm/Ø305mm C5/C6 brakes to Ø355mm/Ø340mm rotors and massive C6 Z06 calipers. Compatible with all Ø325mm kits and brackets.
    Notes:
    Direct bolt-on upgrade for all 1997-2004 C5, C5 Z06 and C6 (std) Corvettes with Ø325mm/Ø305mm front & rear rotors respectively. Minimum required wheel size is 18", however many 18" wheels will not clear the calipers. Fitment template is available for download to verify brake clearance prior to ordering.
    Hub modifications may be required due to the heat dam design of the C6 Z06 rotor. All current and future KORE3 hubs are manufactured to be compatible with all known C5/C6 rotors, OE and aftermarket, however final fitment is the customer's responsibility. Please contact us with any questions you may have.
    Left and right hand C6 Z06 calipers are identical except for location of bleed screws and cross-over tubes. Either hand can be converted to the opposite hand by reversing the bleed screws and cross-over tubes.
    The following items are included in this kit:
    (1) C6 Z06 monoblock, 6-piston, fixed mount, front left caliper
    (1) C6 Z06 monoblock, 6-piston, fixed mount, front right caliper
    (1) C6 Z06 monoblock, 4-piston, fixed mount, rear left caliper
    (1) C6 Z06 monoblock, 4-piston, fixed mount, rear right caliper
    (2) C6 Z06 front rotors, Ø355mm x 32mm, drilled
    (2) C6 Z06 rear rotors, Ø340mm x 26mm, drilled
    (1) C6 Z06 front brake pad set
    (1) C6 Z06 rear brake pad set
    €2999,00
    IVA e spese di spedizione in tutta Italia comprese
    (montaggio escluso)
    fabri
    uau bel kit !
    scusa christian ma se ha capito il cerchi da 17 non basta ad ospitare il caliper, quindi l'unica C5 ammessa è la Z06 salvo modifiche post vendita ?
    fabri
    uau bel kit !
    fabri
    uau bel kit !
    fabri
    uau bel kit !
    fabri
    uau bel kit !
    fabri
    uau bel kit !
    fabri
    uau bel kit !
    fabri
    uau bel kit !
    fabri
    uau bel kit !
