Risultati da 1 a 2 di 2
Discussione: Vendo per SBC teste AFR 1034 195 cc eliminator CNC
    Come da titolo mi ritrovo questi pippocchi di troppo in cantina..
    sono nuove.. mai usate..
    per il momento le metto qua.. mal che vada finiranno sul prossimo 350..
    Brand Airflow Research (AFR)
    Manufacturer's Part Number 1034
    Part Type Cylinder Heads
    Product Line AFR 195cc SBC Eliminator Street Heads
    Summit Racing Part Number AFR-1034
    Cylinder Head Style Assembled
    Cylinder Head Material Aluminum
    Cylinder Head Finish Natural
    Combustion Chamber Volume (cc) 65
    CNC-Machined Combustion Chamber Yes
    Intake Runner Volume (cc) 195cc
    Exhaust Runner Volume (cc) 64cc
    CNC-Machined Intake Runner Yes
    CNC-Machined Exhaust Runner Yes
    Combustion Chamber Style Heart
    Intake Port Shape Rectangular
    Intake Port Location Standard
    Exhaust Port Shape Square
    Exhaust Port Location Raised
    Spark Plug Style Straight
    Intake Valves Included Yes
    Intake Valve Diameter (in) 2.050 in.
    Exhaust Valves Included Yes
    Exhaust Valve Diameter (in) 1.600 in.
    Valve Springs Included Yes
    Maximum Valve Lift (in) 0.600 in.
    Outside Diameter of Outer Spring (in) 1.290 in.
    Damper Spring Included Yes
    Number of Springs Per Valve Dual
    Retainers Included Yes
    Retainer Material Chromemoly steel
    Locks Included Yes
    Lock Style 7 degree
    Valve Stem Seals Included Yes
    Rocker Arm Studs Included Yes
    Rocker Arm Nut Thread Size 3/8-24 in.
    Rocker Arms Included No
    Rocker Arm Nuts Included No
    Guideplates Included Yes
    Guideplate Pushrod Size 5/16 in.
    Valve Cover Mounting Style Center and perimeter bolt
    Accessory Bolt Holes Drilled Yes
    Intake Valve Angle 23
    Exhaust Valve Angle 23
    Valve Guides Included Yes
    Valve Guide Material Bronze
    Valve Seats Machined Yes
    Valve Seat Machine Style 3-angle
    Valve Seat Material Ductile iron
    Steam Holes Drilled No
    Oiling Style Through pushrod
    Machined for O-Ring No
    Heat Crossover Yes
    Quantity Sold as a pair.
    Notes Not compatible with self-aligning rocker arms.
    Su Summit:
    Items:$1,464.65
    Shipping Charge $334.52
    Delivery and Handling Charge $12.95
    Order Subtotal $1,812.42
    +TASSE
    Vendo 1600€ + spedizione
    ne ho montate un paio su un motore ........... e sono spettacolari a dir poco
    peccato non avere din din per prenderle [V]
