per stroker
http://www.ecklers.com/product.asp?p...SJ8PA3DBUJ9DC7
pare che questo distributore abbia tutto
The Mallory Unilite Electronic Ignition Distributor is now considered the industry standard. The device is triggered by a photo optic infrared L.E.D. that never wears out for dependable, accurate timing. This unit replaces the original distributor with a simple three-wire connection. Self-lubricating bushings provide long shaft life, while the high dielectric strength cap and rotor/shutter wheel combination prevent voltage leakage. An adjustable advance curve allow you to tune for performance. Tach drive connection. Also available as a points style distributor
