Grazie Pier!
Il venditore mi ha risposto così:
Hello again Mauro,
Yes, this rebuild kit will work, for your application. Please remember to include that same vehicle info, when placing your order, to aviod delays.
You may want a shift kit as well, from the sound of you shifting problems.
TRANSGO SK 4L60E Shift Kit Reprogramming $37.99
4L60E - HD2 TRANSGO High Performance Shift Kit $79.99
The "SK" shift kits are designed to correct inherent problems in a given type of transmission, and the SK shift kit does not have a pan gasket. The "HD" or "HP" Re-programming shift kits, do that and more, as well as usually having a pan gasket. They allow for customized shift settings, and are used for Heavy Duty & Race applications.
I can add a shift kit, to the rebuild kit box, to save on SH charges. (Would have to re-calculate the SH, if you add a shif kit.)
Let me know,
Rob - TPP
Non è necessario lo Shift Kit per me vero?
