(Post #1 of 169)
Official 2006 Corvette Z06 ***PICS***
0 -> 60 in 3.8 sec.
Top Speed 200 MPH
2,900 #'s
5.7 #'s/HP
Chassis & Suspension development by Pratt & Miller,
Aluminum Hydroformed frame produced by DANA
- 345/30x19 Rears
- 6 piston Front, 4 piston Rear Brake Calipers
- Cross Drilled (cast and camfered) Rotors (possibly Brembo)
Engine Development by KaTech
To be hand built by new HP Engine Plant
LS7 427ci/ 7.0L. 500HP/500 Ft Lbs (512 HP derated to 500HP)
- 2 OHV (3 OHV not necessary for target HP)
- Raced based CNC ported Aluminum Head with 70cc chambers
- 11.0:1 CR
- 46 mm (1.81") Titanium Intake valve
- 41 mm (1.61") Na filled Exhaust Valve
- 104.8 mm Bore (4.125") , 101.6 mm Stroke (4.0") Aluminum block
- Forgrd Crank
- Forged 6 bolt main Bearing Caps
- Titanium Rods
- Cast Aluminum Flat Top Pistons
- 0.591" Lift Cam (15 mm)
- Dry Sump
- 90 mm Throttle Body on Composite manifold
- Ram Air
(Post #1 of 169)
0 -> 60 in 3.8 sec.
Top Speed 200 MPH
2,900 #'s
5.7 #'s/HP
- 345/30x19 Rears
- 11.0:1 CR
- Forgrd Crank
- Titanium Rods
- Dry Sump
- Ram Air
VENDUTA!
VENDUTA!
HHEEEE LA MADONA!!!! ma e' uno sballo!! e il prezzo si sa' gia'???
Una parola sola: BELIN!
